I bet that was a fortune?Mine is 26L and gets up to 50 degrees in about an hour all on its own
North of £450I bet that was a fortune?
Afraid I don't know - I've never seen or used one. I would think they work ok-ish on smaller, lighter components - anything with a bit of mass to absorb the energy, and the effect would be less.@bricol do you think these low cost home ultrasonic cleaners are powerful enough to have any significant effect? I do get a good result from mine sometimes, when I put in a greasy part it comes out clean. But when I put in my Weber carb I didn't really see any effect.
My little L&R tank warms up just from the ultrasonics, it's slow though, I fill it from the kettle if can be bothered.there was enough power in the ultraonsics to warm, even heat, the solution in the tank.
Hi @W.olly. Give me a call about this or message me. It should get up to 80 degrees reasonably quickly. It sounds like there's an issue with a heater pad.I got one and tried it yesterday and today, not amazing but cleaned the carbs. What i found though the heating process is slow, i got the 10l tank digital version. I got it upto 40deg on a 70deg setting and even after removing 3 litres and boiling the fluid and adding it back to the tank at 40deg it only moved the temp up 5deg.
How do you find the heating as in time etc.
I would give @bikers ring about that
Thanks @Brad93 . If a customer has any problems at all, that's what I'm here for. Call or email via our website. I'm being careful about posting links on this forum because previously a moderator deleted them.I can personally recommend best ultrasonic.
Hi Wayne. Yep, I remember. I'll give you a call tomorrow to sort the problem out.Fancy that, it your cleaner i got last week. You called me Waynes Boat Works![]()
It's a grey area. I can understand it when you get people joing just to post links to their business.Thanks @Brad93 . If a customer has any problems at all, that's what I'm here for. Call or email via our website. I'm being careful about posting links on this forum because previously a moderator deleted them.
