Duck
- UK
Yes.Are you gonna try it?
Let us know how it goes as I’d be interested in some of the older stuff I haveYes.
Speak for your self my 2.25 D didn’t leak a drop the gear box and transfer box it poured out of but the engine never leaked. (And yes it did have oil in it)You've clearly never owned a true Land Rover then, as normally you don't have to do oil changes on a 2.25 ltr series engine, it's classed as self servicing oil change engine by most of those in the know....![]()
My brother's audi A5 tfsi had a full engine rebuild at 23,000 miles - cost audi £8,000. He was one of the lucky ones - many customers had to pay out of their own pockets - Vorsprung Durch Technik.as a side note the tfsi audi petrol is said to be ok if it uses less than half a liter of oil in 621miles ,,, [1000km]
so much for eco this and that , all due to having to meet emission regs when new.
Id bung some two stroke oil in the fuel for a fill or two and see if it helps , maybe sticky rings . also worthy of a look at the crank vent set up , that can lead to oil vanishing too.
My old Discovery 300tdi used a lot of oil - until I realised it didn't like being full. Keep it at half on the dipstick and it was fine. Maybe it has it's own level?I've had my Isuzu Trooper 3.5 V6 petrol auto for six months and I've just had to put over 3 litres of oil into the engine to get the level back to max. The car has now consumed 6 litres of oil in approx 2000 to 3000 miles. This is way higher than any car I've owned before. There's no oily deposit at the tailpipe, just dry soot, and no visible oil leak. The car has 110'000 on the clock and otherwise drives very well.
Correct me if I'm wrong, but don't all the common oil loss routes result in the oil being burnt up and showing up at the tail pipe?
I've got a spare Trooper that I use for spares. The previous owner of the donor Trooper kept a log book which shows he was putting in ½ litre of engine oil every couple of thousand miles, which seems way more normal for me. Same engine, and same mileage car. I'm thinking of swapping the engine over.
on my cord
Just a glamorous typographic error.. I wish I had one of those. Looks like it has a fairly significant bruiser under the hood...
That eludes class
I've done the Sea Foam treatment, poured 75ml of the stuff in each cylinder and am leaving it in for two days before sucking it out and starting the engine.for ring gumming / glazed bores, a lot of people on the veg oil forum fixed that by heating the engine up, running it about 1500rpm and then feeding steam from a wallpaper stripper into the air intake :-)
the ones with really bad problems (engine hardly running) or who wanted more preventative maintenance added water injection to squirt a bit of water into the air intake when engine is on boost as you're driving
veg oil forum is dead now but there were some really compelling before/after photos where people pulled heads off to have a look
Because there was a time when you had to pay someone to take it away or give it away, now they'll pay you for the waste oil product.How come veg oil is dead?
Yes, but most vehicles have to run on a mix of forecourt diesel and bio-fuel (veg oil based), cost of converting is less than forecourt fuel but not by much when you take into consideration the other costs involved.£1.10 for new veg oil is still a good saving though?
