Sadly not.You do as you please, will seem a bit strange when your van comes up as an Africa twin.
They can try, they will get told to spin.Sadly not.
They take the plate and send the fine to the owner of that plate.
Then you fight and when they finaly understand you are right and the plate is cloned they cancill the fine. But not give anything else back.
Where is that in Lyme?Got slightly carried away (as usual) in my favourite place in Lyme Regis...
Those saws are £155 new normally, so I couldn't resist a brand new one for £65. They had a Dorchester one as well (also new and the same price) but I couldn't quite justify buying two posh tenon saws!
Good coffee shop next door.Where is that in Lyme?
Lyme Regis, everywhere is uphill.
A friend of ours made polytunnel frames from the curved trampoline tubes, made a really good job.Last night I acquired a 10, maybe 12' dia trampoline frame. Well, in reality I took one down to make way for a veg patch.
What to do with the old frame, tubular steel net supports, bfo disc of black springy trampoline, sections of the safety net that are salvageable?
I kept the frame and springs from our old trampoline for years, ended up in the tip, never used a single bit of it.What to do with the old frame, tubular steel net supports, bfo disc of black springy trampoline, sections of the safety net that are salvageable?
Oh well, just goes to show you really need to change your user nameI kept the frame and springs from our old trampoline for years, ended up in the tip, never used a single bit of it.
That doesn't create a good vision.![]()
