MikeBB1970
- Hayling Island UK
I gained some firewood
4 WD, runs on alegood thing you brought the right vehicle to get the wood transported
Carsten
4 WD, runs on ale
Bamboo plant
It's been in a large plastic tub Carlsten, for about seven years. I think I put bits of brick in the bottom of the pot..How do you keep them in check?
Have you brought in underground ribosome barriers or is it in the pot ..... or do you not yet know that in three years the garden no longer belongs to you, but to the bamboo?!?!?
Carsten![]()
Will you be running around checking how much you are exposing ArdyDam good skip dive today.
I gave most away, before I got pictures.
Mainly drills, screwdrivers, hammers and odd and sods.
Not use to me, but a local MIS did well.
This what I saved for myself.
There was more, but I couldn't get to it.
Unused Draper stones.
A nice sheet metal saw,
Nice little drill vice.
This is a bit like bus's.
Get one and another arrives.
This was a prize find.
Plus, it works.
But to some people , especially when starting out on a limited budget, it's not cheap tat.Never seen the allure of buying cheap tat.
Horses for courses.Never seen the allure of buying cheap tat. They never work properly for very long and quite frankly,I wouldnt trust them. Would land up checking whatever I measure with a decent quality one anyway,so what is the point?![]()
Got a couple of pairs in the truck. If I want to know how big something is whenI’m out and about it’s to the nearest mm or 0.5mm anyway usually. Cheap enough not to worry about but good enough to do.Indeed, and it depends on what you're doing with it. I have one of the Workzone ones, but I'm not using it for very accurate work, just where it's easier than using a ruler for example measuring the diameter of something, and while I've read several times about how to use a manual* vernier I can never bring it to mind when I need it. I imagine to someone doing proper engineering work the accuracy wouldn't be sufficient, but for what I do with it, I can't justify the cost of a proper one. My manual vernier has "Mitutoyo" written on it, looks very nice, cost me £5, but doesn't get as much use as the digital one.But to some people , especially when starting out on a limited budget, it's not cheap tat.
Strictly speaking, the correct terms are probably "digital caliper" and "vernier caliper", with the vernier one being what you refer to as "analogue". A lot of people use the term "digital vernier" to mean "digital caliper", which isn't likely to be true (although it's possible that some digital calipers use vernier tracks to give absolute readings, most are incremental measurements that track movement in order to provide an absolute measurement).( * That might not be the correct term, by manual I mean not a digital one, so perhaps I mean analog)
What about dial calipers? They're "more analogue" than verniers in my mind.Strictly speaking, the correct terms are probably "digital caliper" and "vernier caliper", with the vernier one being what you refer to as "analogue". A lot of people use the term "digital vernier" to mean "digital caliper", which isn't likely to be true (although it's possible that some digital calipers use vernier tracks to give absolute readings, most are incremental measurements that track movement in order to provide an absolute measurement).
I generally buy one new mitutoyo every year. The old one goes for general use and the old general use goes to marking out
But if that’s all you need…The cheapy ones are not classified as Vernier Calipers in my book, more like very near gauges….
