Some really great things you guys have printed
After weeks of humming and hawing I've finally bit the bullet and ordered one.
I hope you have bought some filament.Some really great things you guys have printed
What ya boughtI'm a bit away from printing anything I fear. Its an (ahem) home assembly kit job coming from china (hopefully).
Should be entertaining.
I admire your audacityI've gone with a Voron 2.4 kit from formbot.
hopefully it will arrive here ok. Preferably on a Mon or Fri - as the wife's out those days.
I'm mentally preparing for being in the dog house for some time lol.
I might nick that one if you've no objections! ;o)
That would be very cool if possible ...ta! ;o)Of course not. I should be able to post the model files online somewhere if you like.
Maybe not but it's the smartest wayTis easier to seek forgiveness than permission.![]()
https://www.prusaprinters.org/prints/135991-forstner-bit-rack-drawersThat would be very cool if possible ...ta! ;o)
Very nice. I had been thinking a pcb smd resistor/trace network with a sprung button slider but thats as far as I got.These:
Took a fair bit of time to remove those supports but they all came off eventually:
Getting this 5-pin switched potentiometer in and soldered to the wire was "fun":
I'll probably do a version 2 with better strain relief and the ability to drop the wire in straight, but it's good enough to test the principle.
All assembled: I'm not sure the screw is necessary really as the end caps are friction fit, but I thought it couldn't hurt. I need to shorten the screw slightly when I can be bothered.
It's amazing how obvious the extrusion lines are in that photo - they're much less obvious in real life.
In case you haven't worked it out yet, it goes here...
... and should give finger-tip control of the welding current. The switched potentiometer will start the arc when you turn the wheely thing towards you, then the current should get higher and higher the further towards you it rolls.
I'll test it tomorrow or Saturday and if it works I'll probably print version 2 with a better way of retaining the cable.
I suspect I knowI've wondered how 6061.com has done his button product in such a compact package but Im not going to pay £250+ to find out!
Pressure sensitive buttons are available - https://www.sparkfun.com/products/9375I've wondered how 6061.com has done his button product in such a compact package but Im not going to pay £250+ to find out!
