If your referring to the braided flexi, it is pre assembled in the cistern, it's the link between the iso valve and the cistern level valve, there was no fitting involved it came from the factory, it split from constant pressure changes, the braid gave up allowed the rubber tube to rub on the frayed bit and it went pop, it failed due to the stupid u shape it is forced to be in and probably skimping on a quality part.Never had a problem internally or externally with them .., follow instructions, don’t overtighen fittings
Both, law of averages says they must fail occasionally. I’ve never had an issue personally, and I used to fit the bum wash versions more than the simple ones, more pipes, internal and external connections. Only issues I saw were fitters not reading instructionsIf your referring to the braided flexi, it is pre assembled in the cistern, it's the link between the iso valve and the cistern level valve, there was no fitting involved it came from the factory, it split from constant pressure changes, the braid gave up allowed the rubber tube to rub on the frayed bit and it went pop, it failed due to the stupid u shape it is forced to be in and probably skimping on a quality part.
I just found the whole cistern to be cheap and nasty, the steel frame was good quality but that's where it ended.Both, law of averages says they must fail occasionally. I’ve never had an issue personally, and I used to fit the bum wash versions more than the simple ones, more pipes, internal and external connections. Only issues I saw were fitters not reading instructions
Although you can, apparently, cut the large tiles to fit the slopes of the shower trays our tiler said it never works properly so hence the smaller ones in the shower.
Could well be but geberit are a Swiss multinational that manufacture all over Europe and China.Fitted many of the Gerberit and Grohe cisterns, yes there are some issues like any mass produced part, but on the whole the quality is high.
Did have one failure out of the box, but I understand the operative in the factory was taken outside and shot for dissent when it was reported
German efficiency, best in the world
Always seal the bloody walls , are people incapable of deductive reasoning any more ?
