Memmeddu
- Italia Sardegna
So this Sunday I've actually done something
Repaired two angle grinders from work :an Hitachi G13SW and a Flex L811 ,both had cable fault and carbon brushes.
I believe I should ask money for them ,but you know I think it's better to be the tool guy in the shop so they have a reason more to keep me, even if I do those things in the weekend at home.
Then I've made a power cord for my mag drill ,I do like to do those things very nice and a simple thing takes little bit more time , anyway it's something for me so...
Here we are I've cut roughly 4.5 metres length of H05VV-F 3G1.5mm² cable (from the 20m extension cord bought yesterday)
Then I've striped 70mm of cable outer insulation , and striped the wires , exposing 10mm of copper strands and soldered them.
I've then applied two pieces of heat shrink tubing on the end of the cable
one overlapping the other for about 20mm to make it pretty, and both for about 8mm on the wires.
I've then finally put a IEC 309 230V 16A single phase CEE plug
The cable holding collet bites on the heat shrink tubing , and this last one will act as strain relief.
The other end of the cord will receive the same treatment once I'll have all the parts to complete the improvements on my cheap mag drill.
That's the same process I've used to make my welder power cord ,the only difference is that I've used 3 metres of H07RNF 3G2.5mm² for the welder instead ,same plug too.
This little friend landed on my head and stayed with me for a good amount of time
