I've got an old mitutoyo for that, once they've been dropped a few times I think that's all you can trust them forI keep my old cheapies for scribing lines.![]()
No feeler gauges aren't accurate enough. You need a standard, a gauge block or a gauge ball.sorry but that didnt answer the question lol
You can calibrate them, the barrel can be adjusted.Only the 0-25mm mic would measure a feeler gauge and you could just wind it fully closed to zero it, the bigger ones come with a standard to zero against. You can't really calibrate them.
).Standards are more accurate, feeler gauges can be a bit hit and miss...oh yes, is it ok to calibrate with feeler gauges ?
I'm thinking of calibration like you would an ohmmeter, you can zero it by touching the probes together and adjusting for the leads resistance, but it's a lot more involved to adjust it so that 1 ohm actually reads 1 ohm and 10k reads 10k.
I'd consider adjusting the barrel to be "zeroing" but calibration to be somehow adjusting them so not only does 0mm still read 0 but 25mm reads 25, which you can't adjust. A mic can't really lose linearity like that though so it's not something that needs worrying about, the screw pitch doesn't ever change (Other than with temperature).
If you was a bit older (as In old enough to have owned one long enough)and not a novice machinist you’d know that digital mitutoyo isn’t a permanent purchase and don’t last forever. There’s a 25-50 Mitty digital mike in my scrap !Mitutoyo. You'll have it for the rest of your life
Arguably a mechanical mic can lose precision as the threads wear. (which I wouldn't imagine to be alot if noticeable in a DIY setting)
You calibrate a zero, halfway and full rangeOnly the 0-25mm mic would measure a feeler gauge and you could just wind it fully closed to zero it, the bigger ones come with a standard to zero against. You can't really calibrate them.
A mechanical mike is going to outlive you.
I’ve only gone digital on smaller mikes due to eyesight
Rust from shed storage is the killerI have had some that are bad but not through use but poor storage, straight in the bin.
Oh of course not no digital stuff is gonna last forever.If you was a bit older (as In old enough to have owned one long enough)and not a novice machinist you’d know that digital mitutoyo isn’t a permanent purchase and don’t last forever. There’s a 25-50 Mitty digital mike in my scrap !
Where are you buying from?I'll add another vote for Mahr, sadly my budget doesn't stretch to Mitutoyo, but I've been happy enough with these for digital calipers.
I've also got some old M&W dial ones, batteries never run out on those.![]()
That's why I got them!Mahr is or was top end stuff
That's very cheap.My QuantuMikes ranged from £130 for the 0-1" to £180 for the 3+4".
