Memmeddu
- Italia Sardegna
Disassembled 4 hydraulic cylinder ,two conventional and two with hallow rods .
Welded an hospital cart ,like bodywork welding .
Very satisfying.
Put a part material to make a burning guide to use both the cutting torch and plasma cutter.
Used on a side it will keep the plasma nozzle at 3mm from the plate , resting the retaining cap on the guide
On the other it will keep the cutting tip at 10mm from the plate , resting the tip nut on the guide .
Hopefully tomorrow I can start cutting and welding it together .
It will be roughly 600mm long.
Very satisfying.
Ok so what about a 90 degree chamfer tool, nothing to lose as part is scrap anyway.
