Kero is fine. 5000 hours on mine not bad going!I was under the impression that either fuel was suitable. Have I got hold of the wrong end of the metaphorical stick?
Boats will still be allowed.Marinas still sell red, not sure how much longer though.
As my boats heating is diesel it gets a discount
I wonder what the rules will be on running engines on kero? Mix in a bit of cooking oil say 5% and you won't tell the difference.Nice to hear boats are still allowed but the marina charges 1.41 A liter including the discount so not much better than standard.
All the output ducts I've seen have been the corrugated aluminium type. I think the output can get quite hot so would depend on what the tumble drier hose can cope with.Having bought @skotl‘s other heater and now fitted it in my conservatory, I have a wee question. Is there any reason I cannot use a tumble drier insulated vent hose as my heat output hose.
The reason being, the heater is mounted quite high up to keep it next to the exhaust exit point in the conservatory, and I’d like to extend the heat ducting down to floor level, where it should be more effective.
I've measured mine at 110C which seems a little hot for plasticHaving bought @skotl‘s other heater and now fitted it in my conservatory, I have a wee question. Is there any reason I cannot use a tumble drier insulated vent hose as my heat output hose.
I wouldn't risk it. You will lose loads of heat unless it's in the same room anyway?All the output ducts I've seen have been the corrugated aluminium type. I think the output can get quite hot so would depend on what the tumble drier hose can cope with.
Having said that give it a try.Having bought @skotl‘s other heater and now fitted it in my conservatory, I have a wee question. Is there any reason I cannot use a tumble drier insulated vent hose as my heat output hose.
It’s just used to heat the conservatory to make it a bit more usable in cold weather, without having switch on electric heaters.I wouldn't risk it. You will lose loads of heat unless it's in the same room anyway?
Mine is above my office roof in a freezing warehouse. I also have an insulated return sucking the air from the office so it is recirculating.
It’s not the exhaust pipe, that’s happily vented outside, but the heating vent pipe I want to extend. Being fairly short, is great for heating my head, but carp for cold feet.All the output ducts I've seen have been the corrugated aluminium type. I think the output can get quite hot so would depend on what the tumble drier hose can cope with.
Yes I understand that. My heater came with thin corrugated aluminium ducting for routing the hot air.It’s not the exhaust pipe, that’s happily vented outside, but the heating vent pipe I want to extend. Being fairly short, is great for heating my head, but carp for cold feet.
Apologies, must have misread your post.Yes I understand that. My heater came with thin corrugated aluminium ducting for routing the hot air.
Like this
42 Mm / 1.65 Inch For 2KW Diesel Heater Ducts Pipe Hot A/C Conditioner Ducting | eBay
Find many great new & used options and get the best deals for 42 Mm / 1.65 Inch For 2KW Diesel Heater Ducts Pipe Hot A/C Conditioner Ducting at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
Note this is the smaller diameter stuff - my heater has four small outlets.
That's okayApologies, must have misread your post.
The listing looks a bit more suitable. It has to be better than slotting 3-4 standard diesel heater ducting pieces together. My feet thank you.
have a look through fleabay you might get a better deal. That was the first one I came to. Oh and best to check your outlet diameter as there are several different sizes.
