Alan Reynolds
My neighbour had an EV point installed. Now I know there is a minimum radius for SWA and this isn’t it. Also his spacing of cleats leaves a lot to be desired, as does lazily running he cable along the wall instead of using a few mor metres of cable and going ceiling height where he could have got the radii correct. I would have put the cleats up the other way so that the screws support things although it’s a personal thing. He Moaned about the cross bonding which is in fact correct and also said the cut out fuse was only 60 amp. It’s a 100 amp. £900 worth! I could have done it for under £500.
he could have taken a touch of mortar out of the joint on the corner to reduce the radius
