Dave-sparks
- Woking
To be fair, cable clipped so it is resting on pipes annoys me too - it is just gash.
Usually there is enough room to get the cable behind the pipes without touching them, or route it a different way to avoid them with a bit of planning.
A lot of people seem to start a job and then work around the obstacles as they encounter them, rather than spend a few minutes working out a rout9e first. Something about the five p's...
You wont get the SWA in the pictures behind your average domestic water pipe.
I agree that cables being run in contact with water pipes isn't ideal, and I wouldn't do it like that. But that doesn't mean it is a reason to condemn the installation.
Yes you can put a lot of time in to planning a route, but sometimes you just have to get past some pipework and at that point you have to decide what is actually a reasonable way to do this.
Bear in mind the OP is already condemning the cost of the installation so adding the cost of some containment to pass over the pipes would result in the installer being labelled as even more of a rip-off merchant.
