puffernutter
Puffernutter
- Wiltshire
Are there any nationwide installers or what do I look for in terms of qualifications, trade associations etc., for an installer?
Cheers
Peter
Cheers
Peter
Latest Tesla offers around 360 mile or so ,I was looking in to this at the weekend as I'm contemplating an electric car...
I'd need 16 x 400 W panels (Samsung something or other) feeding 2 x Tesla battery banks (3 would be better) to give me enough range to get to work and back. I calculated it would be around 6.5 year payback in diesel savings alone at today's prices.
I didn't adjust for weekends and used the average number of daylight hours in my calculations.
I think in reality the payback would be sooner given the rising price of fuel.
I met a guy who saaid he had 24 paanels tied to 4.2 KwhrSimilar here, there's actually two separate 4kW arrays. It's hard to directly compare them for a number of reasons but despite the shallower pitched ones having a number of benefits, the steeper ones produce more, and more importantly, more useful electric than the shallower ones.
In a no tarriff situation, without decent storage, it's worth considering and East West array.
4 kw is whats accepted as the normal output your DNO thinks their kit can take.I met a guy who saaid he had 24 paanels tied to 4.2 Kwhr
He reckoned that having the bigger array meant he'd be able to generate the 4.2 easier & quicker than the 16 panel set up's . I you can afford it , it sounds a good idea ......over produce in poor conditions and it can always be trimmed down to the allowed level .
I haven't really looked at legislation as it's just theoretical pondering at the moment.Latest Tesla offers around 360 mile or so ,
I understand that it's now legal to charge up your own batteries an have them wired by a protected inverter to give you 240 volts for car charging . When the Tesla man came to see me I don't think the legislation was place.
The bit I don’t understand is this exporting. I know if the panels generate more than is being used there will be an excess, but how does this go back into the grid? Is it just the case that the meter runs backwards?
You get paid the export Allowance as a percentage of total generated. Even if you use all you generate. You also get the feed in tariff even if you use all you generate.The bit I don’t understand is this exporting. I know if the panels generate more than is being used there will be an excess, but how does this go back into the grid? Is it just the case that the meter runs backwards?
Solar FiTs have stopped. Now you get no FiT and no deemed export (unless I'm mistaken on the last bit?). It's all about using it yourself. Hard, but not impossible, to doYou get paid the export Allowance as a percentage of total generated. Even if you use all you generate. You also get the feed in tariff even if you use all you generate.
I was in early, so I get around 60p per kWh generated plus export tariff. My set up (4kw) was around 12.5k installed at the time. We get payments from EDF four times a year. Usually amounting to around £1800 a year tax free. It's index linked and payment guaranteed for 25 years.
Even at such an expensive installation cost, it's one of the best investments we've ever made.
I'm not sure what the feed in tariff is now for new installs, I've heard around 9p per kWh, but the installation costs have more than halved. So probs not the investment it was, but still ok I would think.
Hope this helps.
You’re a bit behind....You get paid the export Allowance as a percentage of total generated. Even if you use all you generate. You also get the feed in tariff even if you use all you generate.
Hope this helps.
Bought a bungalow 6 years ago already fitted with two sets of panels. Currently receive 14p per kilowatt. Has a 4kw inverter but has never produced more than 2. 7kw.
If I move one set of solar panels to a better location does this affect my fit? Any ideas how to work out effiency for shadows/trees comparing winter and summer.
Think previous owner spent £4.5k installing panels. Had a visit from installers just after we moved in selling battery bank. Wanted £8k for power storage. Insisted that no power went to grid as power only flows like water pipes. I'm not great with electricity but knew that's a lie.
Andrew
I may be a bit behind, but I know for definite I get around £1800 a year, and it's index linked and gauranteed for 25yrs from the installation date. Maybe fit has stopped for new installations?
Would focus on double checking everything is setup and working as it ought to as a starting point. A peak of 2.7kW from a south facing array of ~3.5kw sounds like something is amiss.Hi,
Basically I have about 14 panels on a southern roof and 8 on an easterly roof. Was thinking of moving to a westerly or onto flat roof extension recently put in?
Cons of moving is how it affects fit second there is no obvious place that has good sun in winter. Also worried that securing to flat roof will damage fibreglass roof?
Probably will do nothing as any spare cash is going to be needed to pay power bills.
Andrew
