Onoff
- Sevenoaks, UK
Shocked at that.
t
The capacity of the pun met much resistance
That's because he's got a screw loose.
Shocked at that.
t
It seems to be where the magic smoke decided to make a bid for freedomIs that chip supposed to have a hole in it?? (asking for a friend)
Its running again.. it was an igbt module on the inputThat's fried
OK, I'll edit it. That's a Lot of work. (what's an igbt?)Its running again.. it was an igbt module on the input
My ex. was bipolar, she used to blow fuses as well, big ones, really big ones.Insulated gate bipolar transistor
Two years I'll never want to see again, found out she never took her meds - and never mentioned it to me until six months after I escaped. She died of Sepsis, because she didn't take her meds, ironically she used to be a nurse, sacked for swapping patients meds for placebo's because she didn't believe meds were good for you. I didn't find out until one of her kids mistakenly contacted me thinking I was her latest victim... If she were alive during the Pandemic, she'd be one of the 5G conspiraloons.....These fuses were over 600 quid to replace... what did the ex cost?
We blew 6 fuse cabinets along the line once, doors wide open and smoke coming out.Six 700 amp fuses later, and a service enginèer
Had installed a new pump on a 130 kw motor with Y- D starter, pump to run ccw. Lab manager didn't let us do the connection to reverse motor, use the electrician so it's being done properly was his words. Well, that numpty only changed on Y (star?) so when it switched to delta, well you know what hapoened next....
Whole building was shaking ad we shut down the whole place
I think the most impressive I saw was in the foundry, the wet filter extraction fans were 8' diameter driven by a 250hp motor, we were sitting in the workshop after production finished when one of the fans outside started banging, glanced at the ammeters and saw one pegged at 4000amps then dropped to zero. Went out to look at the damage and worked out the fan had gone out balance (probably lost a balance weight) started rocking until it bent it's 6" driveshaft and locked solid which stalled the motor, found the last couple of feet of cable feeding the motor had melted before the overloads went out. I liked being a sparky, we replaced the cables and tested the motor in a couple hours then went home, the fitters were there most of the night craning out the old fan and installing the spareWe blew 6 fuse cabinets along the line once, doors wide open and smoke coming out.
No.^^ That's what you get for playing with fire![]()
No.
Thats what I get when I buy old things that need some TLC.
I understand you are for sale. Well you neighbours said something like that.
I wasn't sure if they said:I doubt you could afford me![]()
