Plasma cutters?There was a stack of them in mablethorpe lidl on Sunday .
Not on their website.
They reckon 12mm cut? Is that a real 12mm?https://www.lidl.ie/p/tool-time-d-i-y-projects/plasma-cutter-with-integrated-compressor/p18711
Over here 31/1/22 so should be in GB shortly after. Different model this time with a built in compressor but were getting the 40 version again.
EU plugs might be rated at 16amp but British ones are much better with thicker pins.Last time supplies of the 30A were a bit erratic in the UK some shops got 4 or 8 some got none they lasted a day so snooze and you loose.
We get the 13A plug version, the EU one was 40A and needed a 16A supply.
I got a 30A, it'll cut 6mm OK but slow, I think the max was anallegedambitious 9mm - not a hope.
'Twas me. The board has numbers which suggest its a 40A model.I think @Seadog (could be wrong?) did some investigation and found that the difference between the 30 and 40 amp was a tweak of a pot. Obviously on your own head should you decide to do it …
More like 8mm clean cut.They reckon 12mm cut? Is that a real 12mm?
I bought the first one, had to carry it home as well as i only went in for milkThere was a stack of them in mablethorpe lidl on Sunday .
Thanks for the heads up, managed to get the last one in my local tonight.
No price or anything on the shelves.
Did you see the
Portable Metal Band Saw
got to have one of them ......
Reminded me of theseI bought the first one, had to carry it home as well as i only went in for milk![]()
