Karltheboy
New Member
- Coventry
If I use my FE the right way up it will start to freeze, but mounting it upside down avoids that. Keeps the intake end of the dip tube above the level of the liquid gas.I did the same. The reg. froze up all the time, which meant the free gas wasn't worth it.
Mine was also inverted, didn't help though..If I use my FE the right way up it will start to freeze, but mounting it upside down avoids that. Keeps the intake end of the dip tube above the level of the liquid gas.
Perhaps there was no dip tube. Did you try it upright?Mine was also inverted, didn't help though..
norsemensafety.co.uk
All CO2 extinguishers have a dip tube.Perhaps there was no dip tube. Did you try it upright?
If I run into similar problems through using it for longer spells, I will have a serious look at one of those heaters.
<edit>
But not at a hunnert and fifty four quid, I won't.
Or even 200+Noz-Alls Ltd - Welding supplies, welders & associated items
Welding supplies from IGBT inverter welding machines to MIG, TIG, MMA and Oxy Fuel spares. A wide range of brands too. Headux, Jasic, Migatronic and m...www.weldingdirect.co.uk
Co2 Heater 230V | Welder's Choice
Co2 Heater, 230v, Allows flow of up to 40cfh without risk of freezing or noticeable changes in flow/ pressure.norsemensafety.co.uk
But I am not where you are.Bare in mind, when the new laws for disposal of extinguishers come into force.
Using extinguishers for none fire fighting. Or disposal of said units without the correct paper work may lead to a fine or worse.
I think were you are will be following.But I am not where you are.
