The_Yellow_Ardvark
https://www.death-clock.org/
 - Going Away.
Today I acquired this
Not that a vehicle with something like that built into it isn't dangerous enough ....Dangerous things if the spring get away !
Orkney HGV/PSV MOTs are a bit different. We have a tester up once every 4-6 weeks. If you fail that’s you off the road till the next time he’s up. If you can get a retest then. There is always a panic when they are up. He is up all week and I’ve been flat out.
Never ceases to amaze me how rotten a brake chamber can get and still function
Bob
As long as there is enough metal to hold the spring it will be fine
Oh, there was one more toy.
Just the one.
1950 Mamod Minor 2.
With a lot wrong with it.
Wrong burner tray/
Seized piston.
Rust.
Blown Solder joints.
But worth restoring.
Edit.
Cracked base plate.
Just hope he doesn't have any red strips on them or he'll look like a giant high speed used tampon .It’ll be white one-piece leathers next, there’s no turning back now power ranger!
I just love the galloping graduations on the hand wheel ... you'll have to put a comparison list when you get it fitted as what it says on the wheel and what it actually is .
Today again a delivery from Myford country.
Obtained from a well known British dealer in the hope of finally being able to properly level my ML7 and get at every corner of the machine again:
.... but according to the customs papers country of origin: India .....![]()
I can't say that I would now drop to my knees out of enthusiasm for the quality of the goods.
I have seen better ... and much better ....
I now have to measure and compare for parallelism and height - if the hole pattern was right, that wouldn't be all bad either - if that's all ok, I won't grumble about the aesthetics - but I'm getting ready for less aspirational results ...
The pieces in the pictures in the offer of the dealer looked clearly different.
Having a handwheel at the end of the lead screw turned out to be desirable.
It fits, but seems to come from the same dark corner of the city on the subcontinent ...
Let's say: I am less than impressed.
If the parts work in the end it should be good so far - but the stuff also cost money , that was not directly a bargain.
Our problem over here, of course, is that there is no Myford used (replacement) parts (flea) market.
So we must order everything from someone somewhere ...
Buying an English machine in my own country of machine builders - after Brexit - was perhaps not one of my best ideas.
But:
It'll be finein the end,
Carsten
25..4 PM me , if you cover all the costs I'm happy to help .There's lots of secondhand Myford stuff in eBay in the UK. But finding someone to post abroad might be difficult.
People don’t realise you can rotate the top half with the fitting onA lot of it is they get fitted upside down with the drain hole facing up and spend their lives full of water, found this one on one of our trailers.
Apart from that it's perfectOh, there was one more toy.
Just the one.
1950 Mamod Minor 2.
Wrong burner tray/
Seized piston.
Rust.
Edit.
Cracked base plate.
Just don't undo the clamp ring all the way... BOING!Apart from that it's perfect![]()
One careful owner, only used on a Sunday.Apart from that it's perfect![]()
Oh I know.Just don't undo the clamp ring all the way... BOING!
Can’t see it in the pic, but the spring is in 3 bits.As long as there is enough metal to hold the spring it will be fine
