PhillipM
It's a Peugeot TU engine, the headgasket is probably leaking on the front right corner by the oilway, it's closing up when it warms up a bit. Or occasionally the inlet manifold gasket does the same thing (especially the coolant heated ones) - what did the plugs look like?
it's not OBD2 compatible, you need PP2000, the dealer software.
edit: Also sweep the throttle position sensor with a multimeter - they often wear the tracks through just off idle.
