mtt.tr
- Essex/Suffolk border
In your case yesMethods that rely on eye sight are flawed!
Oversize drilled holes can also be caused by the drill bit being sharpened unevenly.Another thing to watch for if you're getting problems with drilled holes being oversized is a bent chuck arbor. Something you'll notice right away in a drill press but not in a tailstock where they don't turn.
Which is very useful on occasionOversize drilled holes can also be caused by the drill bit being sharpened unevenly.
Just a reminder people, that Parm just wanted to true it up
"enough". I didn't get the impression that he was into hunting
down errant microns.![]()
It’s not just oversize holes, the hole is at an angleOversize drilled holes can also be caused by the drill bit being sharpened unevenly.
That’s made me chuckleJust a reminder people, that Parm just wanted to true it up
Classic forumAn advice thread going overboard?![]()
Oh, so, so, true.Another thing to watch for if you're getting problems with drilled holes being oversized is a bent chuck arbor. Something you'll notice right away in a drill press but not in a tailstock where they don't turn.
By angle do mean to the centre axis or just meandering? As you quiet rightly say theorectially it shouldn't happen. Drilling oversize is possible with a good size drill, unless your using a small drill and it's flexing a bit like Dynarod. They drill for oil that way. Saddam was stealing it from Kuwait (one place I haven't worked in) by drilling horizontally. That's possible. Cheap drill and not centred from the off. My cheapo Chinese drills are very much a mixed bag. Had some centre drills where the chamfer had been ground in reverse. Trying to explain to the seller was like Basil and Manuel. But not sure which one of us was Manuel in the end.I am struggling to get my head around how a hole can be drilled at an angle on a lathe when it's the workpiece that's rotating. Tapered I can understand, but angled? Is there some secret 4th axis you've not mentioned?
I don't think this is the problem that Parm is experiencing.It certainly can happen and is more likely than not if you're using a twist drill to drill deep holes. Once they strat cutting to one side you end up with a banana-shaped hole.
TrueI don't think this is the problem that Parm is experiencing.
