The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
New ones.Where do you get your jet prickers from please?
Base camp.
He will have all the spares you need.
Wash the tank well with warm water and detergent.
I need some too saw some on ebay but never orderedWhere do you get your jet prickers from please?
That's what I will do, just gotta be careful as the tank bottom is also soldered, gonna put some sort of heat sync either side and a nice hot flame so as not to heat up the restWash the tank well with warm water and detergent.
Remove all parts not required.
Clean well, with a soft gas flame, flux and solder just sweet it back into place.
Damp rags is what I use.That's what I will do, just gotta be careful as the tank bottom is also soldered, gonna put some sort of heat sync either side and a nice hot flame so as not to heat up the rest
If the bottom seam on the tank goes.That's what I will do, just gotta be careful as the tank bottom is also soldered, gonna put some sort of heat sync either side and a nice hot flame so as not to heat up the rest
Yeah exactly my thoughts, if I don't do it they'll just bend even more, its already at an angle, fry.your eggs at one side of pan only, we'll seeIf the bottom seam on the tank goes.
The saying is.
A world of poo.
It is a bugger to do. It can be done. But it is not easy.
I use electrical solder for my repairs.
Just do itYeah exactly my thoughts, if I don't do it they'll just bend even more, its already at an angle, fry.your eggs at one side of pan only, we'll see![]()
Never tried it but if it does work it may be a cooler flameOut of interest does anyone reckon paraffin blow lamps would run ok on red diesel ?
I suppose it might be a bit smoky or stinky, but for outdoor use it'd hardly matter, and I can get blowlamp quantities free
I'll give it an experimental go when I've got the lamp workingNever tried it but if it does work it may be a cooler flame
No.Out of interest does anyone reckon paraffin blow lamps would run ok on red diesel ?
It could well be worse than very badNo.
The heater coil willl not get it hot enough to turn it into a vapour.
It will not burn.
Don't be a fool and use petrol. That is very bad.
Of course you will always get some one claiming they did, or know some one who did.It could well be worse than very bad
