prepman
- Gwynedd UK
He is more the SCREW IT type of guy I reckonBut do you crimp or solder the terminals?![]()
You have to be careful that the conversion is to "mm SQUARED", and not "mm diameter" - I've been caught out a few times by that.Yeah I've had a few different results trying to Google awg to mm2 sizes!
For what it’s worth, I used to be a precision termination instructor in the avionics sector. My recommendation every time would be a properly crimped connector. With the correct tooling and crimp type a crimp is longer lived and more durable than solder. I have tension tested this many times. It also is the only Technique authorised for cable repair in aviation. Also domestically your not allowed to solder either. There are reasons for this.
That said, those pre insulated automotive type are usually crap.
For most non critical situations solder is fine but lead free solder is more suseptible to fatigue than the old 63/37 solder. It is usually optically nicer then a big crimp too.
Also don’t crimp then solder, it helps nothing and can introduce corrosion from the flux and a break point in the cable from wicking the solder inside the insulation creating essentially a solid core that will fatigue if subjected to flex or vibration.
Dealer-level repairs are mainly crimped using heatshrink covered inline connectors, if pins or sockets in connector housings are required to be changed, they are usually on 'pig-tails', which are crimped to the existing harness. Some manufacturers permit repairs to restraint systems using soldered joints, there is a subset of those that only allow Diag/Master tech's to carry out such repairs as they will have been assessed on their soldering skills.Different opinions from different trades it seems, I’m with Baracuda above, crimps are the best solution, nothing else would be entertained in my industry.
This application seems pretty light duty and very small cables so I’m sure both methods will work just fine, infact in this case I’d say go with the solder if you havent got a quality crimper.
As a slightly related thought, I wonder if the power circuits on EV’s use crimp or solder connection between motors and battery (reasonable amount of current here), I’m pretty sure they will be crimped but seems auto guys on here prefer solder?
Crimps are preferred for two reasons - one being repeatable quality, provided the correct parts and tooling is used, the other being their resistance to vibration stress failures. There are very few soldered connections used on modern (1990 onwards) vehicles, all engine harness' are exclusively crimped connections, including any inline joints.
EV HV Harnesses use crimped connections, although currently repairs are not permitted, only harness assembly replacement.
If there are space constraints, then the joint should be moved away by cutting back as necassary, same goes for bends, multiple repairs in the same area should have the through crimps staggered so as not to appreciably change the size of the harness. VWG specify that the harness should be marked externally with yellow tape to indicate repaired areasAnything factory will be crimped.
Any automotive manufacturer repair manual I've seen will advise adhesive heatshrink butt connectors as the preferred repair method, unless there is a reason they can't be used (typically due to space constraints), where soldering and adhesive heatshrink would be a back up method.
Like all things, the issue is in how well either method is carried out.
Anybody semi-competent is capable of doing a good crimp, but not everybody semi-competent is capable of doing a good solder join.
I know, I've done two replacements today.... and pushed floor grommets out on another so the water can drain out before I do a floor pan harness replacement due to a bulkhead grommet not being fitted properly at build....Correct...![]()
Balanced against the liability of doing something that may fail at a later date due to 'cost cutting' for the benefit of the customer - but will bite you on the arris as a 'repeat repair', all for doing what you think is the best for the customers wallet. Most times, a 'proper' repair is best for all concerned, even if it costs more initially.To be honest - I would always spec up a harness replacement - repair equal to original manufacture.
Then we need to wake up to real world vehicle repairs - costing constraints. What the customer can afford or be willing to pay for.
Don't get me wrong, I/we do lots of harness repairs (except HV) but as soon as you get water ingress to cabin harnesses, it's replacement, no exceptions. Some can be surprisingly cheap, I remember a Volvo V40 (rebadged Focus) with the PSA 1.6D engine harness being around £330 about five years ago, the ECM cost double that! There was a problem on the same vehicle with interior CAN getting a high resistance problem through a connector at the bottom of the 'A' pillar, the official fix was to cut out the connector and put two through crimps in it's place.
