Dr.Al
- Gloucestershire, UK
Hi @selectedgrubHi @Dr.Al I like your machine.
Do you hand work the piece your filing into it?
Or if your filing a key hole for example would you thread the file through a precut hole?
Thanks for sharing, Have a Happy new year.
Thanks. I'm not sure what you mean by "do you hand work the piece your filing into it", but as to the second question: yes. When I made my slow speed grinder a few months ago, I had to cut a few keyways with a file and it's a job I hated. That was one of the reasons I pulled my finger out and got on with making the filing machine. For a keyway, I'd drill the central hole and then slot it over the file on the filing machine. The filing machine can be run without the top support if needed, but I imagine the top support makes for a better cut.
These 3 all have the same centre height - 8mm, 12mm, 16mm. The 20mm+ bars I just clamp directly in a toolholder, although if i had another old boring bar to chop up, I'd make a 20mm sleeve too...
