redlig
- wiltshire uk
What do you do with the time saved?Oh it also changes gear in about 0.2 seconds![]()
Look in my mirror at the manual clutch bikesWhat do you do with the time saved?
Not recently, but I have a feeling the gene pool has weakened since I retired.Have you met many people nowadays?![]()
You need to be prepared when they blast past while you are pressing the reset button.Look in my mirror at the manual clutch bikes![]()
Will be too busy looking at my emails on the dash whilst phoning home to tell the boss to get the kettle onYou need to be prepared when they blast past while you are pressing the reset button.
And E mailing the undertaker and booking a slot.Will be too busy looking at my emails on the dash whilst phoning home to tell the boss to get the kettle on![]()
No need, that is pre programmed in when it senses there is a sudden stopAnd E mailing the undertaker and booking a slot.
Bit of a Bugger if it can't get a signal.No need, that is pre programmed in when it senses there is a sudden stop![]()
Probably I will be past the point of caring if that feature is usedBit of a Bugger if it can't get a signal.
You have an oven as well! not been kicked out the house already?I have taken a leaf from @Screwdriver 's book and had a tidy up and acquired a clean bench and floor space
think of more things to make for the Twin !What do you do with the time saved?
Not yetYou have an oven as well! not been kicked out the house already?
Seriously though, the DCT is brilliant, especially when you have arthritis in your finger joints.
Here is a vid of a DCT Africa Twin, you can hear it going up through the gears and blipping on the way down. It also blips when changing manually via the paddles on the left bar.
Ha ha aye, thought that as well but think it was more for recording the engine sound rather than the riding but maybe notChrist that was painful to watch. Was it his first bike?
think of more things to make for the Twin !![]()
Sounds nice but what was the rider doing?Probably I will be past the point of caring if that feature is used
Beat me to itChrist that was painful to watch. Was it his first bike?
Sounds OK but not a patch on you fellow Scot . The great Bob McIntyre. U tube:-" Manx Norton onboard with Bob McIntyre at Oulton Park circuit Cheshire"Probably I will be past the point of caring if that feature is used
