GraemeVW
- Chesterfield
I suppose old(er) buildings would be more problematic, where the stack isn't built using regular blocks/bricks.![]()
Older buildings are easier, bigger flues.
I don't know whether you know this or not but chmney's are always built on the wonk to give better draught (draft) .
And Wee Dram?No, I didn't know that.My experience of chimneys is limited to sitting at the bottom end, preferably enjoying a roaring fire.
an absolute pain in the hole if mine is owt to go by!!How difficult is it to feed a new 'elephant's trunk' back down the chimney stack? I assume some are a pain due to bends in the building design/layout.
And Wee Dram?
It’s causing a headache!
I think that this forum is spying on me. I am that man with the wet/unbrushed wood stove flu and it's just come to bite me . If plan "c" doesn't work ( home made multi legged spinner ) then it's possibly a liner. Last resort. Any ball park price for 7 meters in a concrete 7" flue . Just to give me an idea of how much to spend on useless presents .Why so bad?
I've probably fitted 8-900 liners and have only been beaten twice.
Thanks for info. Bad news about the beam ! I 'll protect it with a bit of old asbestos sheet. (joke)7" concrete flue? Is it thermocrete lined?
Most new 5kw stoves can go on a 5" liner. Older stuff and bigger stuff needs a 6" liner. 6" liner down a 7" thermocrete lined chimney may or may not work depending on bends etc. Would need checking.
To be honest, I don't deal with our pricing etc so can't really advice on price.
Check prices for decent liner, hanging cowl, adapter, closure plate etc then add on a days wages for a couple of people. Should give you an idea.
However, if you are in England, and want it properly fitted and signed off, that wood beam would have to go.
Thermocrete doesn't often fail though. Are you just trying to get the creosote out? If so, there are products you burn on the stove to dry it out. Takes a few burns and a few sweeps. But if that Is your problem, it would have to be removed before fitting a liner anyway.
Well i would say it was definitely aluminium, not a lot of zinc in it or it would have been fuming. But there must of been a tonne of other contaminants in it. I Cleaned it again and again, you know even a oily inlet manifold starts to weld okay after the second or third attempt.Brad, I noticed you used the work aluminium, they are allegedly French components and are mainly monkey metal with about 1% aluminium in them.
And they are going onto a ????Im not sure ive "fixed" these, though rectified a few issues along the way.
One down, another to go. I love my aqua blaster
View attachment 324588 View attachment 324589
Awesome resto jobIm not sure ive "fixed" these, though rectified a few issues along the way.
Niiiice!Onto a dolomite sprint![]()
