Thank you very much! Iv spent some time trying to come up with a design. So much so, my wife is sick of hearing about this thingHaha. I can already tell you have a well thought out design there. Nice looking welds too.
I am an expert in neither field but I'm impressed with progress and will be very interested to see the result.
I thought that using the gas cylinder was a good bit of recycling and welding practice at the same time. Hopefully come out with something of use at the end.The calor type bottles are a great resource for creating stuff, ( no doubt "Karen" will be along shortly to say you shouldnt do it ! )
I made a couple of "indestructible" fuel tanks, one for a Land Rover, and one for an old Ford tractor.. Plus a few incinerator/stove things of course !
Your project looks great, and as above nice tidy bit of welding..
Thanks gaz. I am still learning with the welding so thanks for the advice .yes block your front holes
you dont want red hot secondary air hitting you when reloading
also block off the rear secondary air holes as you want the air to be further heated before release
i hope your plating the top block in 5/6mm thick plate before the flue
sorry but i dont think your welding is good enough on the thick plate 3mm ( gas bottle ) too 5mm ( plate ) as not a through joint of weld noting that heat will twist and deform steel rather well
I'm using one of the TIG welders from the Jasic/Sherman thread on here bought from the polish company. The welder is fine I'm sure, just I'm not a welder!may i ask what welder are you using ?
heres some of my builds
View attachment 323567View attachment 323568View attachment 323569
Dailymotion
www.dailymotion.com
Sorry, I missed this post. I see what you mean. Maybe I could try to run some weld from the underside? Otherwise I suppose I'd need to re do it?its your plate picture welds that im concerned at as your welds dont go through the material enough as you need higher amps
