selectedgrub
- New Zealand
Or just cries...., with it's blades raised to the sky screaming "WHY"?That cries out to be 3D printed in woodgrain.
End mill in chuck, and bar held in a little homemade jig.Liking that a lot. How was the business end done, slot mill?
What, in the cardboard mock-up?![]()
Today a fisherman brought this in.
And I made half a box of 316 rods disappear and reappear here.
You been at my Soplica?
Not orders as such, just knocked a few up to have as stock, same as I tend to do with pens. Should have started them earlier to get a few sold before Christmas! Drop me a pm if you're interested in one.Are you making to order? They'd make a nice pressie.
Top tip . If you use a frying pan for a seat it MUST be NON STICK.Well I finaly finished one of those projects, first spotted on here and i thought "I can improve/make one of those, for my new improved MkII Tig welding bench, the swing out seat yet to come. Error No1 Snap the tap:
Drill it out:
Being slow in the "learned my lesson" department I then went at it and did it again, didn't think I would get away with drilling it out a second time but to my amazement I did. Not made the thumbscrews yet, but I will, eventually. Works a treat:
View attachment 321827View attachment 321828View attachment 321829View attachment 321830View attachment 321831View attachment 321832View attachment 321833
t is bolted to a realy hefty bit of plate welded to the bench which is drilled and tapped.
The post is a bit of EN something or other that I made into a bearing holder, I dismantled the original swing arm bit and fitted a couple ball races:
it all appears to work well and should stop me scrabbling about for "Bits of stuff"to use as a support and take some of the jerkiness out of my welding, we will see.
