It’s wrong then.Not according to my mpg meter![]()
Wrong, the car uses less fuel if you coast downhill in gear than in neutral.
The on/off throttle method seems to work on petrol cars as well. Agree that it's annoying to passengers. Never done it consistently enough to get a true measure of the gain, though.My BIL used to drive all over the country delivering cars. One day he drove me down the M6 in my diesel Passat and annoyed the hell out of me because he pulsed the throttle, not losing any speed, but just on for a few seconds, off for a few, on for a few, etc. When I moaned about it, he said he did it to save fuel, and sure enough the trip had gone up from mid 50's for me to mid 60's for him!
Steve, spend some time on the autobahn or track and you can see tyre temps soar sometimes!Once the car is demisted turn off the aircon.
Re tyre pressures, I think you should run them a bit high , they are only going to go down. In getting on for 50 years of driving I never heard anyone complain that their tyre pressures had gone up!
It’s wrong then.
Regarding coasting, employed well, it can make a positive difference, even on a newer vehicle.
Yes, modern cars shut off fuel altogether on engine braking but equally, engine braking slows you down. There's a point at which, if the extra momentum gained by coasting is worth more than fuel used to keep the engine idling, you've a net benefit from coasting a bit. Imagine cresting a hill which drops into a valley and crests another hill that's slightly lower than the first crest. If you coast all the way, you can carry enough momentum to crest the second hill at a sensible speed. The whole episode has cost whatever fuel it took you to idle all the way.
The flip side, tou leve it in the topest gear to try to keep revs to a minimum (the fact you do this should hint at the inefficiencies of rotating the engine at a higher speed than needed), you use zero fuel on the downhill but engine braking has reduced the speed you hit the valley bottom. Part way up the other side, you engage throttle to make it over the next crest and use more than the amount of fuel you would've done just idling.
Deciding at what point the net benefit tips one way or the other though is, without lots of testing and more information than is practicable to have and process while driving, rather a seat of the pants guess at best!
Strange that it may seem but a stronger throttle return spring really does make a difference.Ware soft sole shoes. You would be suprised how much you can "feel" through the pedals of what the engine is doing AND how much you can lift your foot up on the accelerator with out the speed dropping (lead footed!)
Uses more fuel.Always coast in neutral/tickover, when traveling on any downhill![]()
I once had the dubious privilege of being passenger of a guy who applied throttle up to 70+, let it coast in neutral down to 50-odd then repeat, ad nauseum, all the way along the M8.That shouldn't work.
Moving an body through a fluid at a certain speed takes an amount of energy. Applying energy in busts will average out at the same amount as a constant application otherwise the body will accelerate or decelerate.
You were a learner driver,Taught me a valuable lesson.
Down side is that engines gearboxes & clutches cost a lot to replace when eventually needed compared to brakes that are cheap even if need more often.The front brake pads on my BMW bike lasted me 45,000 miles. Just changed them this summer. I rarely use brakes much, but prefer to just use engine braking into bends etc. Mind you, I’m hardly a Bazza Sheena on my bike at the best of times.
I get around 50mpg from it,1100cc.
Also get 50mpg from my Diseasel Mondeo 1600.
Uses more fuel.
To further add to that, I drove a friends car, same as mine, that had had the catalysts removed. There was, maybe, a small difference in power but the engine braking was virtually non existent! We can all surmise why that might be the case - catalysts (and dpfs) are a restriction that has to be overcome. Increase the velocity of the gas being pushed through them, increase the energy required to do so, increase the engine braking.
Catalysts and whatnot are not the only things in a drivetrain that sap a non linear amount of energy related to engine revs.
Regardless of perceived fuel savings it is dangerous to coast as you have no engine braking and if you need to slow you’ll have to rely solely on brakes. If you’re on a decline then you can overheat them and suffer brake fade.
Really,Regardless of perceived fuel savings it is dangerous to coast as you have no engine braking and if you need to slow you’ll have to rely solely on brakes. If you’re on a decline then you can overheat them and suffer brake fade.
I think your own words do that best.Does it? Why? If you strongly believe that's the case, can you explain why the following is incorrect?
"It uses more fuel" is what people are told but show me a real world test. Or, at least, attempt to explain with some logic/physics
