pedrobedro
Man at Matalan
- CX near Chesterfield
Why? You'll use more fuel than in gear most of the time.
New cars shut the fuel off when coasting in gear but tickover needs fuel to keep it running.
2004 Megane 1.5 Dci
I agree the Volvo jumps to 99.9 MPG when rolling down hill in gear with the accelerator off.Shouldn't be the case at all, if your tripmeter is anything like accurate instead of overdamped, it'd flick to infinity mpg when you lift off in gear.
Always coast in neutral/tickover, when traveling on any downhill![]()
Not according to my mpg meter![]()
The front brake pads on my BMW bike lasted me 45,000 miles. Just changed them this summer. I rarely use brakes much, but prefer to just use engine braking into bends etc. Mind you, I’m hardly a Bazza Sheena on my bike at the best of times.Try to never use the brakes
modern ....say early 90s onwards cars will cut all fuel in overun so best let the ecu do the workAlways coast in neutral/tickover, when traveling on any downhill![]()
That's why I remember it (I think!).You'd think the opposite would be the case, tailgate on a pickup would act like air brake? Who knows I'm not a wind tunnel technician.
Yes, this! Made a massive difference to older BMW 6 cyl diesel engines, the thermostats all slowly lost strength in them. Swap the 3 stats - get back 5mpg. I've been tempted to try this on the XF but it's a ballache of a job and not cheap either.I have reliably measured a few percentage mpg gains from hotter thermostat temp
That shouldn't work.My BIL used to drive all over the country delivering cars. One day he drove me down the M6 in my diesel Passat and annoyed the hell out of me because he pulsed the throttle, not losing any speed, but just on for a few seconds, off for a few, on for a few, etc. When I moaned about it, he said he did it to save fuel, and sure enough the trip had gone up from mid 50's for me to mid 60's for him!
it depends on the engine efficiency at low loads vs high loads... it may well be more efficient at high loads than small smooth loads.That shouldn't work.
Moving an body through a fluid at a certain speed takes an amount of energy. Applying energy in busts will average out at the same amount as a constant application otherwise the body will accelerate or decelerate.
It also might just be confusing the mpg calculator if it can't keep up with instantaneous fuel rates...
