Kram
- Sussex
Yes measuring I generally look up the 3 wire value on DrAl's site, half it and add my radius to get a target. I use a 0.99mm tungsten as my measuring wire for most threads, and the ones Ive done I note in a little chart on wall for next time.Thanks they look handy , how do you measure the thread depth is that just using a bit of wire between the threads then measure with mic and subract off the diameter if you know what I mean
Important to deburr before measuring or test fitting and get the OD back to the start OD. If you dont deburr the thread will bind, so you take another cut, test fit, nut will deburr, then its a sloppy fit.
