selectedgrub
- New Zealand
90kgs of home growed porky goodness, just waiting on the 4 loins of bacon and 4 legs for gammon
And just enough room left over for victim 6
I see. That would be perfect for when I change the lathe motor over from single phase to 3 phase with a vfd for varible.speed i think
When I converted several three phase motors to run on 240V 3-phase, I also had to change the starter relay switches to 240V so they would work with the inverters.Most 3 phase motors will run on 240V 3 phase, so you only need a normal 240V VFD.
What cores do you use, could do with getting someA larger replacement for my expired hilti,used for core drilling on an sds drive.View attachment 320951
A good friend indeed, nice Optimus camp stove..................................................... From a friend in Guzz.
Hmmm, see the nest post of mine.A good friend indeed, nice Optimus camp stove.![]()
Ok, a little bit of work, but still a nice gift. The 111's are currently going for over £100.oo on the bay of evil.Hmmm, see the nest post of mine.
40/50/70,usually for 25/30&40 square posts,for handrails and railings.What cores do you use, could do with getting some
Yes, I really mustThere is only 1 solution. You need to buy another welder... at least 2nd hand arc welders are usually on one and cheap
sounds like what I'd use too tbh, any cores better than others for the odd hole?40/50/70,usually for 25/30&40 square posts,for handrails and railings.
