Ive used oxy acet to braze them in the past ,,, obviously they need washed out and filled with water or argon or you can land yourself in a lot of bother ,, unless its been empty for a lot of years ,,, if there is the faintest whiff of petrol be very very careful .Morning. I want to have a go at brazing / soldering some rust pinholes in the fuel tank of a collectable old Suzuki. I wanted to use Mappgas. Can anyone run over the procedure and the best consumeables to use?
yep holes in them tend to do that ,, but no harm in mentioning it just incaseit has been empty for a verrry long time
Well, in theory the t’s a good fix, but they do go wrong, and then you have problems.If it's only pin holes then I wouldn't braze it but use one of the 'Petseal' mixes that you pour in the tank and slosh around. I did a very pin holed Honda Dream tank a while back for someone and it worked very well. Do any external repairs with molecular metal or the like first. New 'Petseal' is even suitable for use with bioethanol added unleaded.
. The problem is the petrol is in the rust. So if you are going to braze the holes play the torch very Slowly over the area at arms lengthThis is true - first a soak inside with phosphoric acid will shift the rust.Hi . I was asked to braze a bike petrol tank when I was an apprentice. Soaked it in soapy water for a week and it still went off!! nearly turned the tank inside out with my hair on fire. The problem is the petrol is in the rust. So if you are going to braze the holes play the torch very Slowly over the area at arms length
Soft solder was always the way pinholes were repaired. With a big soldering iron you don't need to get a flame anywhere near the tank, so why use a method which may blow your head off? Large patches are welded or occasionally brazed as you can purge the tank while you have a very big hole in it. Nowadays you can cheat with epoxy, which works fine. Those slosh sealants can and do start coming off and blocking fuel lines, I wouldn't use them.
if your brazing them its best done with oxyacetylene not just mapgas its best using localised heat . failing that you can soft solder the pinholes using a nice big copper soldering iron heated over the gas ring and tin itMorning. I want to have a go at brazing / soldering some rust pinholes in the fuel tank of a collectable old Suzuki. I wanted to use Mappgas. Can anyone run over the procedure and the best consumeables to use?
LolBloody ethanol.
