Could be a lot worse, i was following some cows being driven along the road, the first car in line was a sports car with the hood down. The cows were all milling around a bit, one backed up & let the lot go, straight into the drivers lapYou are probably right - run over a cow pat in a cycle-wing equipped Caterham Seven, and you can see it come forward out of the wing, thrown forward . . . problem is, it slows down a lot as soon as it comes off the wheel, so you tend to catch it up . . . out of the corner of your eye you can see it coming towards you . . . you can certainly hear it "SPLAT" on the roll-bar by your head . . . as long as you don't slow below 50mph, you can't smell it much . . .
Some nice joinery skills thereOn Friday I finished making a pair of peg looms as presents for my mother and my other half. Each one looks like this:
but can be split in two and used for narrower stuff like this (also shown with loops through the pegs for wider "warp" threads):
They can be clamped down for use like this:
I also made boxes for peg storage (in this picture you can see the dowels that hold the two pieces in line with one another - drilling those holes accurately took a bit of thought!):
A better photo of one of the boxes filled with pegs:
Peg looms are Oak with 10 mm Sapele dowels. Boxes are Walnut & Oak. Everything's finished with Danish Oil. The top two photos were taken on a much dingier day than the others: I need to take some more when the weather improves!
Do you sell them feller? And do you have a goldfinch oneSome slate coasters on the cnc laser. I’ve drawn about eight different birds, which usually takes about two hours each on the computer. The laser engraving takes about two-three minutes.View attachment 319003
I put them on Etsy the other day just to see what would happen (and of course there are thousands of slate coasters on Etsy, so I’m not holding my breath!). I don’t have a goldfinch, but that could be remedied. I’ll have a go tomorrow and stick a photo up for you.Do you sell them feller? And do you have a goldfinch one
I might know someone that would like those too.....I put them on Etsy the other day just to see what would happen (and of course there are thousands of slate coasters on Etsy, so I’m not holding my breath!). I don’t have a goldfinch, but that could be remedied. I’ll have a go tomorrow and stick a photo up for you.
Why is there a raker missing in your building?A bit more done to the hopper.
View attachment 319423View attachment 319424
I have decided to extend the top section which is a bit of a pain as it means another load of welding but with the limited room I have I don't think the hopper will hold enough bulk so I have no choice.
So tomorrow I will be cutting a few more bits of aluminium up ready for welding on on Thursday.
It will hopefully end up like this
Not my building (wish it was ) and no idea what a raker is so...Why is there a raker missing in your building?
That first picture can be confusing, first thing in the morning (not fully awake)Made a bit of a hopper extension this morning and stuck it on.
50mm box with some galv sheet welded on.
It now needs extending up the conveyor to the top of the handrail.
It was all done pretty quickly and a bit rough.
View attachment 318892View attachment 318894
What model is your 'toy car' !Put the toy car away and made room in my garage.... the measurements I made when I moved the shelving in the summer seems about rightView attachment 318896View attachment 318897View attachment 318898View attachment 318899
I don't think you are Hoarding Ali, or anythingGot the box section for the hopper chopped up, also the 12mm plate for the stiffeners at the top.
Most of the box is just straight cut at the ends but the 4 gantry ones have angles at either end and are diagonal, so basically 12 degrees at one end and 6 degrees at the other. Made up a simple jig (just a piece of 12mm cut at 45 degrees) so that I could position the box diagonally in the vice which made life easy.
At a guess, possibly a Robin Hood?What model is your 'toy car' !
They lift the cod end with the gantry then open and let the contents into the hopper, here is a previous one I did.@Hood, what does this hopper do?
