Ordered, thanks, looks like the best option under £100.Very happy with mine - under £75 from here https://www.hisltd.co.uk/ProductDet...lmet-SH-5-13/8ee5dd0bbd4e4ef1aaa795b434c56895
Over £100 everywhere else.
I have one and can vouch for it. Well worth £75.00, I paid nearer £100.00.Very happy with mine - under £75 from here https://www.hisltd.co.uk/ProductDet...lmet-SH-5-13/8ee5dd0bbd4e4ef1aaa795b434c56895
Have a look if you can change the batteries on your cheapy. You may have to cut the case open to do it. but it is possible. And 1,fun? to do 2, It doesn't go to landfill and 3 saves you a bit of dosh.
It'll be interesting to see what you get - the one in the link has been superseded by GYS to one with a '+' it appears to have a rating of 1/1/1/1 and a faster reaction time.Only annoyance is GYS are French. I imagine price went up with brexit but maybe HIS may have pre-brexit stock.
Looks like its been sent and should be here tomorrow
I poked the old one. Has two lithium coin cells 2430 inside. Does the solar recharge them, or have they lasted 10 years. Measures 2.9v. I have left it out in the sun, is it worth replacing the cells? I would still abuse it for stick and any galvanised as I can use my p3 mask with it.
dis you get guardian 50 or guardian 62?I treated myself to a new mask. Didn't have a clue but wanted full colour, so took the advice of the shop.
Bought a... Bohler I think it is (suggested over the popular & oft-quoted Parweld by WSD). Full colour, external knob to be able to adjust shade level with it on, and a Grind button below the knob (which I won't use). Comfy, nicely adjustable headband and general fitting and flip, good clarity and a big step over my cheap Sealey - so I guess it's a good un.
It's the Bohler Guardian 50.dis you get guardian 50 or guardian 62?
I´m looking for chinese lcd:
ARTOTIC SUN7B (Sherman V3b )
SUN9BX (Sherman V4)
SUN20B (Sherman 5a)
I think that are the same lcd that parweld uses but at a lower cost. As it is imported to europe i think that they have to comply with european regulations so it will be safer than buying directly from china.
There is a newer lcd that has 5 sensors.
It arrived as a 1/1/1/2, so its not the latest + model. What do you have?It'll be interesting to see what you get - the one in the link has been superseded by GYS to one with a '+' it appears to have a rating of 1/1/1/1 and a faster reaction time.
Mine is the same as yours, I think the 'white' LED torch puts out composite light from one source whereas there are three primary light sources in LCD panel so more blue end of the spectrum will be output.It arrived as a 1/1/1/2, so its not the latest + model. What do you have?
While the amazon is 1/1/1/1, I cant really tell the difference between them except the amazon has the iridium mirroring on the outside, they are the same looking through side by side.
I havent tried welding yet.
They share a very similar adf design apart the lid shape. The amazon is more comfortable but slightly less secure, and smaller.
Silly question here - for testing they both trigger by tv IR remotes. They dont trigger by a super bright led torch - fair enough the sensors dont work on visible light. However they do trigger from phone and tv LCD's. Whys that then? Lcd's are usually visible light only.
Yup, that's it in a nutshell.do I need to set the darkness to what I feel it the best for what I am doing and hence increase the setting on the side if I feel the arc is brighter than I expected it to be?
you still get all the UV protection regardless of shade, it's about comfort and being able to see the puddle
Thanks for that Munkel,You could run at shade 6 for welding if your eyes could stand ityou still get all the UV protection regardless of shade, it's about comfort and being able to see the puddle
