zzr1200
Working at 650 ft on open steel work.
- Glapwell, Chesterfield, Derbyshire, UK
Small trees then, not a problem to cut.Approx: 2 @ 40/45cm, (dead/dieing)
2 @ 20cm Living.
I have a Huskvarna chainsaw, but although I have stripped and refurbished it, it will not run. It only starts if I put petrol in the cyclinder, but will not run beyond them few seconds. Very dissapointing.
I could look at the saw for you and try to get it sorted if your interested?
. That's on the larger trees, the smaller trees and branches I use a smaller axe called a T193 also by the same axe manufacturer. The smaller one can be used in tight spaces with one hand
I have a telescopic handle for it, extends to 12 or 14 feet. The knife edges are good for vines or ivy but I tend to cut them off when the blade is more used. The blade is a 390
