Ubique
- East Midlands
You can use a wedge to help if the gob is slightly off - well that's what I do.Wedge is for tipping the tree over not aiming. The gob is the directional cut.
Felling (forest) axe and a splitting wedge to help aim the fall. A hand axe is best on dry or dead wood, there is a lot more control with a felling axe and you can put the power in properly without injury to your muscles / spine.
Gränsfors Splitting Wedge | Gränsfors Bruk Sweden
The Gränsfors Splitting Wedge is twisted with a grooved poll, bevelled corners and a hardened tip. Splitting wedges are used to split really big, knotty or cross-grained logs.www.gransforsbruk.com
Note there is a world of difference between a felling axe and a splitting axe.
I don't generally use a wedge if I'm using a chainsaw, the splitting wedge was an idea I had when the gob was slightly off on a tree I was bringing down with a felling axe.
As above as either
chainsaw
Silky
Axe and saw for back cut
in that order.
Decent silky will race through them. Watch your hands. They have a habit of jumping till they are a few strokes deep.
My bold - I probably didn't. Last time I did that (it wasn't something I'd habitually do) the tree was probably 350mm dia. and 12-14 metres tall. It was enough to adjust the fall so it didn't glance off or get hung up on another tree. Given the choice, I'd use a chainsaw, sometimes you don't have one to hand though.Assuming we are talking about trees big enough you can't just push in the direction you want them to go.
If you have a a decent hinge with a proper step for your back cut then putting a wedge in shouldn't be able to alter the direction the tree is going.
Nope, check your gob before doing the back cut. If the gob is wrong, make it right by recutting it. Then do the back cut. Forcing a tree can cause the hinge to break prematurely, letting the tree fall where it wantsYou can use a wedge to help if the gob is slightly off - well that's what I do.
Well I know that now....Nope, check your gob before doing the back cut. If the gob is wrong, make it right by recutting it. Then do the back cut. Forcing a tree can cause the hinge to break prematurely, letting the tree fall where it wants
Going by the state of the edge on the head of that axe I'm guessing he drinks babycham and calls the AA if he gets a puncture
As above as either
chainsaw
Silky
in that order.
As above as either
chainsaw
Silky
in that order.
My silky is a two handed one or it can be put on the end of an extending pole. I have more problems with the end of the pole hitting you where you don’t want hit !As above as either
chainsaw
Silky
in that order.
Approx: 2 @ 40/45cm, (dead/dieing)What diameter trunks???
Possibly the best answer is a chainsaw depending on location and area available to fell in.
You could always pm me with more details, I've just serviced my saws.....
Buy a Chinese carbApprox: 2 @ 40/45cm, (dead/dieing)
2 @ 20cm Living.
I have a Huskvarna chainsaw, but although I have stripped and refurbished it, it will not run. It only starts if I put petrol in the cyclinder, but will not run beyond them few seconds. Very dissapointing.
Two are about 4ft only, and the other with twin trunks proably 12ft only. None are near buildings.Depends how many trees there are.Felling axe definitely better than hand axe, but for speed, chainsaw. Also depending on the height, weight and proximity to buildings etc dropping trees in the desired place is a skill. Once they're on their way down you can't stop them.
Two are about 4ft only, and the other with twin trunks proably 12ft only. None are near builrings.
I wonder what brand of felling axe is 'sought after', in terms of decent quality?
