Pete.
- Kent, UK
Kurtis only uses inset tooling. All that requires is to set the tool height by some permanent method (grinding the holder or fitting a fixed shim) and he can swap and change at will.I think if I had a working 4 way I'd be happy enough. Am i right in saying that if you buy all the same size tools, then they all run with the same centre height? I've watched Kurtis from CEE swap out tools all the same height in his 4 way, no shims. But he runs 4 way tool posts because of rigidity for huge tools etc. Any qctp will have more overhang and less rigidity.
