tommy_lad
- Warrington, Cheshire
It's a Kerry AG, I posted about it a few months agoWhat lathe is that?
It's the Kerry AG I got a few months ago, apologise I was just talking in general terms regards missing gaps, what was the problem with fitting the toolpost? I didn't touch the lathe to make it fit, just measured up the slot and milled up the base that came with the toolpostI assume he also has a triumph by the wording lol
He managed to get the QCTP on by the looks of it and i remember you having a lot of bother and deciding not to fit one in the end as you would have to butcher the cross slide was it?
Yes thats it.I assume he also has a triumph by the wording lol
I was struggling to find a decent 4 way to fit mine so ended up with this, it originally came with the lantern style...Yes thats it.
I have learnt to live with the 4 way. Massively rigid.
Bit of a pain using shims to get centre height spot on.
I now have a parting off tool. Standard cut tool and a fine finish fitted. Leave one spare.
Really looking forward to the rigidity of this machine after using a mini lathe, Not that I've got to balls to do depths of cut high enough to use all the horsepower and rigidityYes thats it.
Yes my thoughts exactly.Oh my mistake, nice looking lathe that just had a look on lathes.co.uk
Never even heard of the lantern style one , look intresting but a bit of a faff
Alot of my tools are from the bloke selling and looks like he has already welded some shims onto them so could save me a bit of messing around. If the tailstock is at centre which it hopefully is unlike your one originally. Atleast other tools only need shimmed once same as setting height on QCTP and for the cost of them and butchering the casting I know which one I would have.
The lantern was a pain to set, why would you have to butcher the casting?Oh my mistake, nice looking lathe that just had a look on lathes.co.uk
Thanks, missed that<<The lantern was a pain to set, why would you have to butcher the casting?>>
Look at the diagram at the bottom of post #111. The Triumphs came with one of two styles of compound slide casting: one with an inverted T-slot like your own, the other with an integral stub to suit the 4-way post.
I have tried some pretty hefty cuts and the lathe just laughed at them.
And that photo of the topslide shows why you cant use a QCTP.Tool post apart and hopefully refurbed and back together tonight we'll see how I get on
Quite sludgy old grease here so glad I took the plunge to take apart not as hard as I thought
All in bits don't think I've lost any springs or bearing so all kept safe in a bag View attachment 317400View attachment 317399
Getting on with the big parts first in the washer and attacking with some scotch brite
And ways look good on this aswellView attachment 317405
Just thinking of what I will grease and what I will leave to oil when I put it back together.
Didn't stop me on the Student I had, off with his headAnd that photo of the topslide shows why you cant use a QCTP.
One huge central post - one piece with the slide.
Certainly is extremely rigid![]()
Best mod I ever did to the lathe, well that and the DRO.Could always modify one to fit though.And that photo of the topslide shows why you cant use a QCTP.
Make your own....
And spare holders are far from cheap.
Kurtis only uses inset tooling. All that requires is to set the tool height by some permanent method (grinding the holder or fitting a fixed shim) and he can swap and change at will.I think if I had a working 4 way I'd be happy enough. Am i right in saying that if you buy all the same size tools, then they all run with the same centre height? I've watched Kurtis from CEE swap out tools all the same height in his 4 way, no shims. But he runs 4 way tool posts because of rigidity for huge tools etc. Any qctp will have more overhang and less rigidity.
