sprayerDrew
Perfession not a hobby !
- uk
Maybe if you have a big welder with long hoses 18 would be good, or if your working outside a lot.
Pretty sure they do a 12lpm, which should be ideal for most things.
Obviously, if you only use 12lpm, instead of 18lpm, your cylinder will last about a third longer.![]()
Er...50% longer.
36l lasts 2 mins at 18lpm,
36l lasts 3 mins at 12lpm.
Why would you want to add a tap, or flow meter... the whole point of the integra cylinders, is you dont have rubbish like that to wory about
The reason i added the tap Hitch is to quite simply reduce the gas useage,the majority of my welding is indoors,so by reducing the flow even more my gas bottle lasts longer without compromising the quality of the welds,if i need to do any welding outside i simply open the tap up,not being able to workdue to ill health means i have to save where i can.
