Yup got confused there the dials have back lash so was thinking just to be sure when taking a final dimensions cut I could use the dial guage to measure my depth of cut rather than dials which could have the backlash mess up however ways around that I supposeA DRO doesn't have backlash, you're thinking of the dials.
A dial gauge is almost essential equipment for turning on a lathe.
He did indeed.Did you get the gap piece with it?
That's good, I looked through all the photos but couldn't see it. Must have been hiding so people wouldn't be too jealous!He did indeed.
A find a DRO essential on my mill. Not so much on a lathe now I have got used to dials. I am sure would be very nice to have though.
It took me forever to get the hang of them as wellI always get confused with my Colchester dials because they indicate the amount of material off the diameter, not the depth of cut.
err, or is it the other way round...![]()
Soo which way round is it for future reference lolIt took me forever to get the hang of them as well![]()
Gap piece but not screws for it so will need to sort those out then get it in.Did you get the gap piece with it?
Same here, I dont think I would want a mill or lathe without a DRO, being able to switch between metric/imperial at the push of a button is invaluable.
Bob
I am lucky all my nipples are perfectWas going around all the oil points last night putting a good bit in before moving it all loads to make sure its all lubricated , mainly on the apron. For some reason the cross slide I think its called at the red arrow , It was a bit stiff to turn took two hands at first but pumping oil through it freed up a little down to stiff for one hand. I think one of the issues could be the oil points as some seem perfect the ball is on the spring and moves but other oil points seem all crusty and not moving hard to tell if oil is going anywhere.
This is the main center one for the compound slide , It was worse before so used some thin Wd-40 pressuried oil to try and clear it out a little so ball moves around but dosent spring up
Then for the compound slide arrow labeled dial this is the oil point
Then on this one I believe the cross feed slide
That was alot more free and could move it up and down fast with little bother however the oil point does look a bit messed up
Was watching a restoration on youtube and he punchs these out from the inside and replaces them just pressure fit, Im not really looking to strip it all aprt like that so was thinking If i could use some sort of puller to take them out and replace.
That is the compound slide. On the later Triumphs there is a single setscrew for you nipping it up to lock it. Looks like the earlier ones have a gib there and 4 screws. Loosen the screws then retighten until you just feel pressure whilst sliding and then check there is now movement radially on the slide and you should be good to go...., mainly on the apron. For some reason the cross slide I think its called at the red arrow , It was a bit stiff to turn took two hands at first but pumping oil through it freed up a little down to stiff for one hand. I think one of the issues could be the oil points as some seem perfect the ball is on the spring and moves but other oil points seem all crusty and not moving hard to tell if oil is going anywhere.
