It does, but it has limitations.Still confused. Mine runs my lathe perfectly and has done for years. But I thought thats what a static phase converter did anyway...allowed you to run a 3 phase motor from single phase?
The static converter relies on the load motor to stabilise the false phase (the actual produced phase, is an interaction between the induction load, and the capacitors). If all you want to do is run a single motor, then a static converter can work well.
The benefit of adding an idler motor, is you can power things other than just motors.
I ran my CNC lathe from a rotary converter, but I couldn't do that with a static converter.
Now I run everything from a 240 -> 380V VFD, although I still kept the idler motor to provide a bit buffer for shock loads, and to ensure the VFD had a bit load.
One thing I have noticed since going to the VFD, is the idler motor runs noticeable smoother.
A limitation of using capacitors, is the false phase is rarely perfect, both in voltage, and timing, even if your measured voltages are perfectly matched, the phase timing can still be off. This shows up as vibration as the motor accelerates/decelerates when the false phase is the main power source, in a similar way to how a single phase motors speed varies as it rotates. It's especially more noticeable when using modern light weight motors, which don't have the same rotating mass to help smooth things.
