The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
No.Half a playful puppy?![]()
A leaf, the parcel is waiting to go.
No.Do a proper obd2 instead of the onboard diagnostic, then you’ll get some results
No.
Have the van taken to a garaged and fixed under warranty.
Plus the body work done as well.
The main dealer has sent a report.Then why complain about the onboard diagnostic not working if you have a solution? Seems strange.
I would check both iacv and pcv Valves. But as always you have all the answers.
The contents of the box, as received.
Ooh a porta power, or at least a porta power clone. Very niceThe contents of the box, as received
The first, but I am too tired to investigate further tonight.A vehicle body re-aligning jig? Or the makings of an hydraulic press?
After seeing @8ob's wee tractor last time I was up in his yard and my ride on taking a hammering doing some stuff it's really not designed for I picked up this last Monday. This was it the night (well early hours of the morning) I got back after a jaunt up to Durham to collect it, and a hitch-hiker in the form of @Nomad.
Then yesterday I acquired (again at @8ob's recommendation) a wee 4ft flail to go behind it. With the roller does a very nice job on the lawn and has just spent 5h today going through about an acre of 2ft high rushes. Ideally needed a bit more power but flail did a neat if somewhat slow job*
* Given a 180hp tractor with a hedger was struggling with the rushes I think the little 17hp 1220 did alright considering it was driving a 4ft flail.
Used to have a bigger one but was too big for my place. The intention of this one was to replace the ride on without being too big.Tractors are the best purchase, so versatile and an excellent brag when you become the guy who can pull someone out of a ditch or drive across a bog - marvellous!
More stuff,I’ll post the whole job eventually.View attachment 315474View attachment 315475
Didn't get the phase converter from Lidl. Its not a VFD, just a straight phase converter as I don't need the variable speed drive. It will work for either my ancient Herbert surface grinder or Opus Die filer. I made up a box to accommodate both, and rather than hard wired them in; and have added receptacles to the box so that it's possible to simply plug in other three phase machines if needed.I'm going to Lidl in a minute, are the VFDs next to the baked goods or in the middle?
I got the split pin and washer set's, but haven't thought to check if either are stainless ?I got the bits from Lidl this week, split pins and grub screws. The Lidl colour is usually blue for stainless so I’m hoping that’s what they are
