MattF
- South Yorkshire
I could tell you about the time a "person who self abuses himself" was found helping himself to my tools.
A nice helping off deep heat to his pot of Haemoid cream.
You're a bad man.
He stole my tools.You're a bad man.![]()
Just a side to side weave most of the time but just watch the pool to see how it is filling and move accordingly.Ooh soo many questions...
Is that a slight up and down weave?
What's with holding the chisel to it ?
To dissipate heat ?
316L or other flavour.
Surprised how much rod you put in for such a short bead.
Nice welding.
Well this needs explaining ! exactly how intimate with said person were you to be able to deposit deep heat in their Haemeroid cream ?I could tell you about the time a "person who self abuses himself" was found helping himself to my tools.
Not at all.Well this needs explaining ! exactly how intimate with said person were you to be able to deposit deep heat in their Haemeroid cream ?
conjours up all sorts of johnny english type escapades .
It made it very hard for the workshop manager to pace the blame on any one.Well that was a very boring reply !
He stole my tools.
Is that cutting freehand or on a CNC machine . I bet you could do at least 10 mean sets of Santa and 7 reindeers just in time for crimbo crap & auction sites at £50 or more each .Got bored with the plasma tonight.
View attachment 315277View attachment 315278View attachment 315279View attachment 315280
I was in the bath after a hard 10 mile cross country race in Cumbria .. ached all over .I could tell you about the time a "person who self abuses himself" was found helping himself to my tools.
If I stood my sharpened tungsten's up like that I guarantee I'd push one down the back of my nail at sometime or other . I just have mine laid flat in a plastic caseView attachment 315460
Tungsten pot.
the thought of that proper made me cringeIf I stood my sharpened tungsten's up like that I guarantee I'd push one down the back of my nail at sometime or other . I just have mine laid flat in a plastic case
They sound good, I’m looking for something similar - have you got any pics?Got a lot of 250W LED floodlights, only been up 5 weeks and removed due to the company deciding to demolish the building, took my brackets down and fitted new tops to accept the larger mounting holes and they will be going back up to replace the smaller ones, also got the back up battery pack which needs mounting inside one of the barns.
Thanks for the links! I’ve never been bothered to hack one of my spare PSU’s but this makes it soo easy I might actually be able to use them for somethingThat was a bit if a hacked mess.
The simple method (which I'll use for my third attempt!) Is buy one of these.
24/20-pin ATX Computer PC Power Supply Breakout Board Adapter Extension Module | eBay UK
The adapter board only plays the role of electric power extraction. Board Size: 69.2mm x 63mm. 24Pin Extension Cable Power Port Multiplier Male To Female Port Y Splitter Cable. 18AWG 30CM SAE 1 To 2 2 Pin Quick Connect Disconnect Plug Extension Cable.www.ebay.co.uk
And one of these.
(Make sure you get one with a built in current shunt.)![]()
Mini Digital Voltmeter Ammeter - 100V 10A - Voltage Current Meter w/ LED Display | eBay
Display: 0.28" Red + Blue Dual LED Display. Working current: <20mA. Size :48x29x20 mm. Current: Range x 0.08%+Two decimal point. Red line (thick): IN+, current input. Refresh rate: 3hz. You get 1 of -.www.ebay.co.uk
And wire up as per the diagram in the second advert.
Going off subject how do keep the discs from falling off, mine won't stay on (same sander)Wall bracket for 12" sander.
Made from scrap. First arc welding project. Pls don't zoom in on welds!
They're not pretty but I don't think it's going to fall apart, even with 33kg of sander on it.
Fastened to the wall with resin anchor studs.
View attachment 315091 View attachment 315092
I've always cringed when I see sharp things standing up ever since I poked an eye out with a mapping pen aged 5 !If I stood my sharpened tungsten's up like that I guarantee I'd push one down the back of my nail at sometime or other . I just have mine laid flat in a plastic case
Pens and pencils in jacket outside breast pockets is a pet ha
I just made sure the plate was spotless, It was greasy when it came. Cleaned with thinners then meths until the cloth was spotless after rubbing. No problems as yet!Going off subject how do keep the discs from falling off, mine won't stay on (same sander)
