What is that aluminium exhaust ducting like for durability? Seen it on amazon and Im looking for something for my lathe extraction vent. I imagine stainless flex would be better but cant see any available.Cobbled together a power supply for the Diesel Heater from an old ATX PSU .
Worked okay but 9amps @ 12volts not enough I'll try the higher power one at some point.
Puts plenty of heat out.
No idea on the ducting I've just popped it on today to see if does anything. Bet your nan is chuffed with her chair stander.What is that aluminium exhaust ducting like for durability? Seen it on amazon and Im looking for something for my lathe extraction vent. I imagine stainless flex would be better but cant see any available.
Sorted out my tig bits into one small box. Im unable to seperate the #6 glass cup from the collet body!
Nans chair stander got painted. Her chair is red so used the hammerite.
Where does the exhaust go?Cobbled together a power supply for the Diesel Heater from an old ATX PSU .
4" hole in the wall, the inlet and exhaust come out the bottom of the heater and then outside.Where does the exhaust go?
Could you put together a tutorial of the bits you used if you get some time please...Cobbled together a power supply for the Diesel Heater from an old ATX PSU .
That was a bit if a hacked mess.Could you put together a tutorial of the bits you used if you get some time please...
Washing up liquid and a fine needle ...eye first using long nose pliers down between the ring soap and glass every so often ?What is that aluminium exhaust ducting like for durability? Seen it on amazon and Im looking for something for my lathe extraction vent. I imagine stainless flex would be better but cant see any available.
Nice machine , when you sort things like that with no diagrams it can be a good feeling .
With luck you should be able to still locate test & service schedule sheets or even a complete hand book that gives voltage test points in each building block of the circuit boards somewhere on the internet .
