aye was wondering that, if you could have machined a ring to take a steel plate, that was consumable, but I suppose by the time you've done that, then faffed about getting teh worn and old bolts out etc, you be quicker skimming as you say....
			Dog wash perhaps ?What’s the low sink / bath (?) for?
It's so the seven Dwarfs can do the washing-up for Snow WhiteDog wash perhaps ?
As Rob said. Dog showerWhat’s the low sink / bath (?) for?
Final push tomorrow.Me and mate did a bit of a garage conversion type job with a big tray and thermo mixer just for washing the 5 or dogs they had , thats a bit posher though
When you gonna get that door on !
The 500 door idea is mine tbh. Easier to stick a 1000 corner base divide in the 600 and hang a new door than it is to modify around the soil pipe and fit a new unit.I do love it when kitchen planner go theres a couple of end panels and a door to make that .
Wrens painted range are only pained both sides on one edge. Pita as standard practice for me to split a panel in half when used mid run.I've had the same a few times with end panels , usually when the front edge has a slightly different profile and you can't rip a piece of the front and back of panel to make something up , Normally there not very happy when you point this out and want more panels .
When I was starting out as a SE alarm installer for a company training me up ( 1982 I was fitting hidden sunken magnetic contacts to the top of a door & frame .Dog wash perhaps ?
Skirting in both rooms. Seal the shower (grouted earlier gotta love rapid set) freezer door on. And make some changes to the poor design to make this section look finished rather than a bodge. Swap 600 for 500 door add frame and infill.
Situations like that I usually knock up a clamp. Bit of 2x stock with a half round of the correct diameter jigsawed out then clamp it down each side of the 2x stock.I came into my local men's shed the other day to see two of the guys drilling into the end of a 3" cylinder of wood about 9" in length with a fairly big Forstner bit. One was operating the pillar drill, the other holding on tightly to keep the cylinder level (kids, don't try this at home!). OK, so it worked, but the risks were pretty high to say the least. I decided to knock up a vice that could hold a piece of round, square or rectangular timber so that the ends could be drilled. Now we don't have any milling or turning equipment or other more sophisticated machinery for that matter, so everything I make tends to be done mainly by hand. The vice is a mix of offcuts and reclaimed steel including Dexion racking angle for the slide guides. It may look crude but it does do the job.
That's nice & handy if the guys have the presence of mind & intelligence to use it .I came into my local men's shed the other day to see two of the guys drilling into the end of a 3" cylinder of wood about 9" in length with a fairly big Forstner bit. One was operating the pillar drill, the other holding on tightly to keep the cylinder level (kids, don't try this at home!). OK, so it worked, but the risks were pretty high to say the least. I decided to knock up a vice that could hold a piece of round, square or rectangular timber so that the ends could be drilled. Now we don't have any milling or turning equipment or other more sophisticated machinery for that matter, so everything I make tends to be done mainly by hand. The vice is a mix of offcuts and reclaimed steel including Dexion racking angle for the slide guides. It may look crude but it does do the job.
