slim_boy_fat
- Scottish Highlands
We have a forging hydraulic press. I should build one really. The price of 60T rams is putting me off lol.
Ahhhh, you're planning a 'proper' capacity one, mine's a puny 10-ton job.
Yes it is actually a close fit.The grooves don't necessarily have O-rings. If the quill is a close fit they serve as a rudimentary labyrinth seal.
No, o rings don't sit in the grooves. The grooves are the seal. The muck collects in there with the idea being it doesn't progress past both of them.Someone had been at the quill/spindle before looking at the state of the quill seal and missing I presume two o rings that sit in the grooves.
View attachment 289074 View attachment 289075 View attachment 289076 View attachment 289077
It's an absolute nightmare to fit the angular contact bearing to be honest. Very tight fit in quill housing and spindle.Bit of a thread revival here! A question for @Brad93 - could you tell me how the bearing fits were on the spindle and quill ?
It seems from the thread that the bearings are press fit into the quill ? And then does the spindle slip into the inner races or are one or both of those tight also ?
I'm interested because I'm looking at the bearing setup on another drill press (a Kerry/Qualters and Smith) and I'm trying to compare.
Thanks !
J.
I was reminded by this when the bearings were £380 each, getting complacent when changing 4 pairs of them nearly cost meThe thinner outer race side is the thrust side, so the right hand picture.
Preload on the meddings isn't adjustable as far as I know.Duly noted. It seems hard to get solid info on the best order of assembly.
Is the top (deep groove bearing) also tight onto the spindle ? I'm trying to figure out how the preload is set on the bearings and where the retaining ring over the top bearing comes into the picture.
If the top is angular contact too then there will be a thread and jam nut on top of the spindle To set the preload between the two opposing bearings at the top and bottomThanks for the info @Brad93, @Mark Davison .
The Kerry/Q&S drill press has similar size bearings, but with the top bearing being the angular contact one. I'd love to know the rationale in each case as to how the bearings are designed to carry the loads, axial and radial.
