Yes, only about 45% of this car has been replaced. This is what I would class as a light restoration of a 54 year old car.It's looking good! but is there any of the original body left?
I'm not keen on solid mounting as it transmits a load more noise and I've had to weld up quite a few toe boards where they have been fitted.With a rubber mounted subby I would get some solid mounts fitted first...
Well no more noise than pre rubber mounts, and people do fit them on the back only, which is a disaster leading to cracking. With the standard rubber mounts, open the bonnet, get someone to waggle the wheel - first +-5 degrees it’s the subby that moves. Took me a while to work out why the first one I had years ago used to move around on the road until I discovered this.I'm not keen on solid mounting as it transmits a load more noise and I've had to weld up quite a few toe boards where they have been fitted.
Yes, maybe that extra length helps. The teardrops? Pah, what do they do? Very little I would say due to the front end flex, but they do add some stiffness I suppose.On the rubber mounted subframes minis, replacing the Top and tear drop mounts gets rid of the movement in the front frame and stops the weaving under heavy braking.
Doing the rears just cracks the toe board, on the solid mounted earlier minis the frame is longer and attached to the body more securely.
So where are the shims located? Behind the panel but in front of the subby?You have to have the front sub frame fitted and with 1 or 2 shims on the front bolts to fit the front end panels. Without it you stand no chance of making things line up.
Is that a question?Better not mention my original 1071 engine then, whats that worth.
(no migs about then)Yes, that's correctSo where are the shims located? Behind the panel but in front of the subby?
