slim_boy_fat
- Scottish Highlands
Joiner is desperate for them
What are they?
Depends if there is an internal wall in the way . . . or a burning door . . .The door is less than a foot away, how dumb would you have to be to try to get out that window
Given it takes a not so long time to die from smoke inhalation . . . and it takes a bit longer for the fire brigade to arrive, work out whats what, and that you are on the floor the other side of barred window . .. I think being able to self-extract right at the begining, or at least open the window to scream would be a good thing!my thoughts, exactly, and since when did the fire brigade ask for keys ?, in the event urgent access is needed, an axe would pretty much open anything they need?
Hope they are high tensile no6 screws going in there ! Leverage of a heavy person in a rush carrying an plump baby landing on one of them . . .connectors for a wooden staircase with a central spine
here's one of the treads on a test piece of the spine. The wooden tread is screwed to the connector.
Just a thought - when the Fire Brigade came round offering fire prevention advice and free smoke alarms, they gave my neighbour a right bollocking for having the windows locked with a key . . . the time taken to find a key and unlock them to get out if other methods of egress were blocked could be life threatening . . .
£50 quid well spent on the floor buffer. Made life easier today.Cover it up in the morning and start getting the kitchen/utility in
View attachment 311693 View attachment 311694 View attachment 311695 View attachment 311696
Hope you did the floor cleaner rodeo!!£50 quid well spent on the floor buffer. Made life easier today.
I had to look at it 3 times, and only knew they weren't cast because I knew you'd plasma cut the hooks themselves!Thanks. Die grinder did most of the work.
Just a burr. Started out with the Pferd Steel range, but they can make a right mess as they're incredibly aggressive, then swapped to the Pferd TOUGH range which are a lot more controllable a little less metal removals.I had to look at it 3 times, and only knew they weren't cast because I knew you'd plasma cut the hooks themselves!
Burr or stone? Or both?
If I tried that with a die grinder and burr, I'd end up with a mess...!
