stuvy
@Agroshield is there much difference between aluminium and bronze for flow?
...is there much difference between aluminium and bronze for flow?
The sintered sheet is better for making back up or purge boxes.
Already spoke to them waiting for the sample to come but not sure they have the correct spec
Iv found a supplier that will send me a sample of the aluminium so will test that out and see what comes backI have never seen a form of aluminium that would allow flow as such, so I do not understand the question. As far as I can see from the Aegis Ceramics' site (http://www.aegis-ceramics.co.uk/pormet.htm - also two pages linked off this page), you can sinter the bronze to a range of porosities/flow rates (makes sense - golf balls glued together will flow more than garden peas glued together).
If the sheet form is hard to come by, one of the circular filters cut into four quadrants laid adjacent to each other might do the job. If you can find one big enough and cheap enough, an arc segment of it would do. The tfifilters people imply that sintered filters are available in stainless and other more exotic materials, so maybe omit 'bronze' when you are searching.
Fritted glass is essentially the same structure but in glass, probably just as difficult to find sheets though, and obviously very fragile.Would there be a porous ceramic that would work?
Is it for welding or something else?
Tread carefully. You've already got HFT and a danish firm at blows over a purge gas diffuser. There are many patents believe it or not.
