northwest
- Manchester UK
Nor have i
Like, back this up with links, pictures or documented facts.
Now there's a thing. Is rubbish factual? Can you "in fact" have rubbish?
Nor have i
I'll back it up with the experience I have of Dirty Pro - my uncle bought a 6" bench grinder and a bench top drill press. Both are, in my professional opinion, "rubbish". The grinder doesn't have the power to grind - barely enough to sand, and the stones aren't even slightly balanced. It's not even good enough for DIY use. The drill press is flimsy and likewise powerless, although I suppose you could drill 6mm holes in steel with it.Nor have i
Dirty Pro are a Derbyshire retailer just rebadging generic items in their brand, cheap andoftenalways Chinese rubbish.
Had the same issue with mine, all the parts looked OK but still leaked under pressure. I got one of theseok ive took it off completely so could take to local compressor shop but they don't sell these and can't get me one, so i took it apart and this is whats inside , all looks clean as well
the one i had was the same and letting air past the rubber seal as it was slightly worn like yours . i just rubbed it flat on a bit of emery cloth and it stopped leaking past itok ive took it off completely so could take to local compressor shop but they don't sell these and can't get me one, so i took it apart and this is whats inside , all looks clean as well
which i think is a tad expensive, so now looking for a way round maybe fitting a smaller size can i reduce the 1" so can fit one off the standard size valves like was suggested a few msgs back
