Hood
- Carnoustie, Scotland
I got a control handle in to repair.
I was going to vee it right out, fully weld then bore/tap but when I took it apart it had a helicoil in so I wondered if I could just weld it the way it was. Vee'd it out a bit and clamped to a chunk of steel.
Filled it up with weld.
Ground flush and it seems to be doing its job.
Next up was a steel hauler knife, both sides worn, normally I would tig but decided to give the wee stick welder a go on pulse and see how it performed.
Seemed to be fine so after 5 or 6 2.5mm rods I ground it down.
Repeated on the other side.
Job done, not sure if it was much quicker but I was wanting some messing around with the pulse function as I haven't had much chance to use it since I got it earlier this year.
. On commercial boats I change out the fluid every two years, this stops the jelly forming and blocking the schroder valves. Just my two cents worth
![IMG_20210921_160634963[1].jpg IMG_20210921_160634963[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/306/306908-3673391d33161b4485d47ef7fb187f7b.jpg?hash=NnM5HTMWG0)
![IMG_20210921_160639222[1].jpg IMG_20210921_160639222[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/306/306909-b5941f35d7486d275ffa6bf47d8ddcee.jpg?hash=tZQfNddIbS)
![IMG_20210921_164820266[1].jpg IMG_20210921_164820266[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/306/306910-faf23bab6fc5f42ec1ef329e923c39c1.jpg?hash=-vI7q2_F9C)
![IMG_20210921_164833028[1].jpg IMG_20210921_164833028[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/306/306911-f09f60a5eb7c43dd1f746b593514f4c3.jpg?hash=8J9gpet8Q9)
